29 Oct 2023 02:05 PM - last edited: 30 Oct 2023 10:10 AM by KevNewMedia
My my printer keeps looseing the signal so my wifi goes off keeps saying no internet connection any advise
Moderator note: subject of thread updated to better reflect the conversation
30 Oct 2023 07:37 AM
Posted by a Superuser, not a Sky employee. Find out more@Rod4 if other devices are connecting normally it could simply be the printer is getting insufficent signal.. Most printers use the 2.4GHz Wifi band which is very prone to interference from your neighbours' networks if you power down your hub it will find the best channel when it reboots which might help but dont be surprised if you have to do this quite frequently. Ideally reduce the distance between the hub and the printer.
