Discussion topic: The Worst Wifi i've had in over 15 Years (Sky Max)
Message posted on 12 Jul 2025 10:05 PM
I was with BT for over 15 years and recently moved to Sky FTTP (500mb)
The Sky Max hub (white) - I dunno it's just very unreliable. I can have a strong signal, then my devices will just drop and have to reconnect.
Sky Q mini box for example - i've had to re connect it 3 times this week.
Is there any plug and play routers anyone can recommend?
Message posted on 13 Jul 2025 07:29 AM
Re: The Worst Wifi i've had in over 15 Years (Sky Max)
@azza19892 with the white Sky hub the Q mini has timbe connected to the main Q box by WiFi not to the hub. If you are doing that and the mini is losing connection call Sky as they should supply a Q booster.
The nearest to a plug and play router will be one ofvtge range from Asus but you will have to configure the unit yourself but losds of walk throughs on this forum if you search.
