Discussion topic: The WiFi didn’t work
This message was authored by: Tingxuan
Only the power light is on, the other two are dark
Re: The WiFi didn’t work
@Tingxuan
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
