Discussion topic: Terrible wifi
Message posted on 10 Aug 2026 10:23 PM
Terrible wifi
Message posted on 11 Aug 2026 06:54 AM
Re: Terrible wifi
@orpheus51 soeed test report the slowest part of the connection which if you are using a device connected to the hub by WiFi is that last bit. If that applies you have poor WiFi coverage in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
