Discussion topic: Teckin smart plugs
This message was authored by: Albatross1
Teckin smart plugs
Like a lot of 'new' sky customers when I switched to the sky hub my Teckin plugs decided not to work. After much research in various places the solution found here worked ie:- switch off 5Ghz band and lower security to WPA2. With rhe Teckin app I was able to connect the plugs (8 all told) then after downloading the Teckin skill to Alexa the plugs became operational.
What I would like to confirm now is:- Can I return the hub to function in dual band if the security level reverts to the higher level as suggested it might?
Re: Teckin smart plugs
@Albatross1 Yes get the dual band on, do not cripple the system the IOT devices will more than likely hang on now they are connected!
Security should still stay fixed on the WPA2-PSK mode.....
