Discussion topic: Technical fault
This message was authored by: Manc1
Technical fault
Sky   There is a technical fault. Please try again later.  The programme suddenly stops and the television freezes.  Happened all day yesterday and had happened again.  Says all my services are working fine so don't understand what is happening.
Re: Technical fault
@Manc1 check the indicatir lights on your hub when you lose connection and follow the steps here https://www.sky.com/help/articles/hub-lights-explained-start
