Discussion topic: Technical fault...
This message was authored by: Lisa354
Technical fault...
... again!! Every day, I have a problem with broadband. KT9 area.
Re: Technical fault...
@Lisa354
When you posted the same issue last year you never replied to the help you were given which was to run these tests:
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
