2
This discussion topic has been answered Discussion topic: Tapo camera not identified by the Sky Hub Max Router
This message was authored by: Trebboy
My TapoC320WS camera is not being identified by the Sky Hub Max Router, it worked ok with the Sky Q router in 2020, but since I have upgraded to fibre, the new router does not ide
Avatar for Trebboy
This message was authored by: Trebboy Answer
Re: Tapo camera not identified by the Sky Hub Max Router
              Changing the settings failed,  i then connected an ethernet cable, and finally completed the setup; it also allowed me to setup the wificonnection? I will prove this works ok tomorrow.
@Trebboy
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Avatar for Trebboy
