5
This discussion topic has been answered Discussion topic: TV keeps dropping connection
This message was authored by: gosgutho
Hello. New customer here. My router is in the hallway and raised off the floor but one of the rooms upstairs still has a weak signal and the TV in it either cannot connect to the WiFi at all, or when it can connect, drops soon after connecting. Phone, laptop and iPad also struggle sometimes. It's very frustrating.
This message was authored by: Tom-W19 Answer
Re: TV keeps dropping connection
Hi @gosgutho
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
@gosgutho Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Avatar for gosgutho
Thanks for your reply Chrissie. I already have Sky WiFi Max but no pods. I tried calling customer service but got directed to this forum for help. It sounds like I need to fathom how to get through to an actual person
Hi @gosgutho
Tom
This message was authored by: Lindady
Our internet connection drops out at least 3 times a day on the tv . The phones and I pad are ok . It takes about 10 minutes to get it reconnected . Why is this happening please . We keep having to press the WPS button to get it back and then it still doesn't always reconnect and we have to do it again . We pay £70 a month for this . Please can you advise
thank you Mr and Mrs A Whitehead
@Lindady
Try running the line test here:
If this is of no help give Sky a call to report it to them.
