4
This discussion topic has been answered Discussion topic: TP Link Entry Level Model with Sky BBand
This message was authored by: ArnieRHC
I live in a sprawling bungalow so our kitchen is MILES from the living room. Sounds cool right. It is not. Can I use one of these halfway from the rooter to the kitchen to boost the signal around a corner or two?
TP-Link RE330 AC1200Mbps WiFi Extender Booster, Ethernet Port, EasyMesh, WiFi Booster Range Extender.
Please and thanks.
AS
Re: TP Link Entry Level Model with Sky BBand
@ArnieRHC it is best to have a matched units using TP-Link device to extend a Sky wifi signal is not sensible as the two could interfere. A better suggestion is to look at buying a powerline networking kit that will use your home's mains wiring to get the data to the kitchen. These kits can be boughtvwith a built-in wifi access point. The alternative would be to turn off the Sky hub's wifi and buy a whole home WiFi set up with say 3 satellites to give strong wifi in every room.
@ArnieRHC Would help if you say what sky Hub you have, takes all the guessing out!
Avatar for ArnieRHC
Thanks Jim. Not sure if that is truly helpful but here goes...
Its a Sky Q Hub
@ArnieRHC That hub goes obselete Dec so link is below for you to deal with, if you have not been informed, missed etc but sky are controlling the release to the replacements the Sky Broadband Hub.
The booster you mention is fine for operating and especially on the newer hub!
www.sky.com/skyhuboptions
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
