Discussion topic: TP Link Connection
This message was authored by Jantavia This message was authored by: Jantavia
TP Link Connection
Having issues connecting the TP Deco  link, when contacting them they ask me to ask my provider if it was either one of these
L2TP
PPTP-DFlite
Vlan
IPTV
static
I have ADSL Sky network anyone any idea?
Re: TP Link Connection
@Jantavia
Is your address in the UK or RoI?
Sky UK uses a somewhat less common connection method which some router models do not cater for.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
L2TP
PPTP-DFlite
Vlan
IPTV
static
@Jantavia
If you have an ADSL connection then you should be authenticating against PPPoA (or PPPoE, I can never remember which is correct) - in the UK or ROI.
UK VDSL is not the above and the Deco's struggle with an 'easy' connection method if you're trying to use them to replace the Sky Hub, you could
connect them to the Hub, in AP mode and turn the Wi-Fi on the Hub off.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Jantavia
@Skull+Treaty
Thank you so much for your answer much appreciated
