Discussion topic: System management: Problem with broadband
This message was authored by: Sue4447
Connection to Internet
Re: System management: Problem with broadband
@Sue4447  For the community to help you'll need to priovide a bit more detail.
Avatar for Sue4447
Level 0 icon
Connection to internet
No internet connection. No network connection.  It says they cant connect to internet. I have tried switching off and on.
@Sue4447
If you mean your broadband isn’t working, use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
