Discussion topic: Switching to Slky Broadband - How will installation happen
Message posted on 03 Jan 2025 01:14 PM
I've signed up to Sky Broadband from eir.
Will I get the router in the post, or will an engineer come to the house.
Message posted on 03 Jan 2025 01:20 PM
Re: Switching to Slky Broadband - How will installation happen
Your router will be sent out to be with you up until the day before activation
Message posted on 03 Jan 2025 01:26 PM
If a first time FTTP installation is involved then installer attendance is required.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 03 Jan 2025 01:27 PM
Thanks. I'm not in the UK.
Message posted on 03 Jan 2025 01:27 PM - last edited: 03 Jan 2025 01:37 PM
Ah, in the Republic of Ireland things are rather different, but FTTP still requires attendance if an optical connection isn't already in place.
I don't know if it's the same over there, but in the UK the presumption is that FTTP will be used if the wider scale infrastructure is in the area.
