03 Jan 2025 01:28 PM
03 Jan 2025 01:36 PM
Posted by a Superuser, not a Sky employee. Find out moreThe first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
