2
This discussion topic has been answered Discussion topic: Switching to OpenWRT - port forwarding/DMZ question
This message was authored by: WhiskerP
Hi
I have my router working behind the Sky router with IPv4 double-NAT etc.
IPv6 isn't the problem here but I'd like to switch to my own OpenWRT router with MAP-T support. I do get an IPv4 over MAP interface come up which works. It has a different public IP address (same 176.25. subnet) presumably due to the router MAC being different but I'm not sure if it retains all the port forwarding I previously set up. Is there any way to set up port forwarding on the SKY public interface over MAP-T with your own router as the facility disappears from the Sky spp? The router is set up but no packets arrive. Thanks, Peter
This message was authored by: Danz994 Answer
Re: Switching to OpenWRT - port forwarding/DMZ question
Posted by a Sky employee
Hi @WhiskerP I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for WhiskerP
Hi
They appear to have switched me to dual stack so issue is no more.
Peter
