Discussion topic: Switching supplier
This message was authored by: Sarahwi
Switching supplier
Well appears Sky are no help so if you are not delivering what I am paying g for that means you are in breach of the contract and I can move suppliers
Re: Switching supplier
@Sarahwi
What are you paying for?
What speed are you getting?
What is the issue?
This message was authored by: daveNOS
@Sarahwi Actually no it doesn't, If the issue is related to your line and Sky cannot get it fixed via Openreach then  you should be offered the option of leaving, if the issue is related to WiFi connections or issues inside your property then that wouldn't trigger the option to leave as it would be down to you to fix.
Nope: broadband delivery is 'best effort' based on national infrastructure which Sky doesn't own or operate, as @daveNOS indicates.
If you leave arbitrarily then it's you who are automatically in breach of contract.
Avatar for Sarahwi
Cheers
engineer checked the line and no issues, guy even fitted a new box inside and yet still keep losing signal
@Sarahwi
That probably suggests the issue is WiFi rather than broadband: ISPs will provide a limited amount of help with that (typically at extra monthly cost) but a better investment may be a third party mesh wireless system.
