Discussion topic: Superfast
This message was authored by: bracasper
Superfast
Just change to super fast boardband min download 58 bps
still only getting 37mps so is it me are has changed over
Re: Superfast
@bracasper are you measuring speeds at the hub or on a device? If the latter the difference is likely to be slow wifi. You can check the speed to the hub by running the Service Checkin the My Sky app which will also give you the guaranteed speed for your line. New lines take 10 days or so to settle so Sky wont zccept fault reports during that period
