Discussion topic: Sudden internet blackout
This message was authored by lem3k This message was authored by: lem3k
We've had our service installed less than 48 hours and today have had a sudden full internet blackout. No phone, broadband, or wifi and all Q boxes show an X next to network connection.
The hub was showing 3 green lights and one amber (on voice).
The service status page on sky says "issue detected in your area", but when I go through to check status it says "the page you are looking for cannot be found". If I run the "check my products" options and run the broadband test then everything comes back as being fine(?) and says there aren't any outages - despite us clearly having no internet.
Restarting the hub seems to have resolved for now, but I'm concerned this has happened so soon after signing up and all the 'help' information contradicted itself before leading to a dead end without actually providing any support.
Is there a better way to get through to someone for help in these circumstances? Are these disconnections normal?
Re: Sudden internet blackout
@lem3k certain faults in Sky's network of a radius server failure can cause the conditions you describe  fortunately they are rare and a hub reboot usually connects you to a different physical unit. Sounds like bad luck
Running the connection test requires a connection to your hub so fails if there is no link. Running the test over a mobile connection will tell you if there is a known issue but further tests needs the hub to repond.
lem3k
Thanks. The odd thing was the connection test was coming back fine, despite us having no connection.
I'll put it down to bad luck for now.
lem3k
Well, this has happened again this morning. So it seems this is either not that rare, or I am very unlucky to experience this twice in the first week.
