26 Apr 2022 12:35 AM
my wifi was good, out of no where there is no broadband connection, no signal what so ever
the wifi box showed one yellow light, it is not flashing, just yellow
26 Apr 2022 08:19 AM
Posted by a Superuser, not a Sky employee. Find out more@TeeK123 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
26 Apr 2023 01:24 PM
Many thanks - same problems in NW2 area
Done diagnostics - highlighted problems
Had engineer out this morning
Better for a while - now running slow and dropping out again.... 😞
26 Apr 2023 01:35 PM
Posted by a Superuser, not a Sky employee. Find out more@JLucyS Well if the fault is still there and the broadband test is showing this then get them back out again to fix this ongoing fault.
