Discussion topic: Stream issues
This message was authored by: Nick167h
Stream issues
Hiya
We are having numerous issues with our Sky Stream set up.
First, it's impossible to get the sound synchronised with the picture. I have tried adjusting the delay on the TVs but it makes no difference. This happens on TV channels and streaming services.
Second, we keep getting the loading/biffering circle on the screen. There are two of us in the house so we are not a heavy use household and we have 500mb broadband so that should not happen.
Third we get internittent interuptions in the programmes when the screen goes black for 5-10 seconds and then restarts. When it restarts the timer bar is on the bottom of the screen and you have to puase and re-start to get rid of it.
Fourth we get intermittent "there is a technical fault with this programme. Please try again later" message.
Finally we are struggling to get a decent signal across the ground floor of the house casuing Spotify and BBC Sounds to drop out constantly.
Sorry for such a long e mail but we have a number of issues.
I have tried resetting everything numerous times which solves the issue for a day or two but then it returns.
Thanks a lot
This message was authored by: peter-marlow+1966
Re: Stream issues
Have you  tried  the sound settings  on the tv ? Itself
P c marlow
Avatar for Nick167h
Level 0 icon
Re: Stream issues
Yup makes no difference. We have three TVs and they all have the same issue
Re: Stream issues
Is the puck connected  by  wifi ? I  have my 2 55inch sky glass tvs and my puck  all connected  by ethernet cables and I  have no problems, just saying I  have  1 sky glass tv 55inch gen 1 and the puck since November 2021 and a 55inch gen 2 since March, i am on gigafast broadband 900mps aswell  and the puck is connected to  a 43inch lg smart tv that is well over 10 years  old i  did have to adjust  the sound  settings  on the lg tv when I  first got the puck and the sound settings  on the puck  to but ever since  then they have been  fine hope you get it sorted out  soon
P c marlow
