This discussion topic has been answered Discussion topic: Static IP route
Message posted on ‎06 Mar 2025 06:30 AM
I expect the answer is no, or at least I have not found the ability to do so, but I am trying to add a static route to my Sky Max Hub. I wish to have several subnets supported on my network.
Message posted on ‎06 Mar 2025 07:27 AM
@Psiman none of Sky's domestic hubs support subnets you would need to buy and use a router that does and also supports Sky's authentication which primarily requires support for DHCPv4 Option61.
