Discussion topic: Speeds to hub
Message posted on 13 Apr 2025 05:10 PM
Speeds to hub
Message posted on 13 Apr 2025 05:30 PM
Re: Speeds to hub
Have you done a check on your broadband speed with the my sky app and the speed that you are paying for is the speed to the hub
Message posted on 13 Apr 2025 05:35 PM
Re: Speeds to hub
@Gt77 Use the link below, you can also see the last 30 day's of operation to the Router.
Re: Speeds to hub
Yeah,but I can't seem to get an option for actual speed,,they're just checklist saying all good,,I think my speeds are lower than what I'm paying for,,that's what I'm trying to check before I get in touch with them,,thanks
Message posted on 13 Apr 2025 05:36 PM
Re: Speeds to hub
Google a speed test and try that aswell
Message posted on 13 Apr 2025 05:39 PM - last edited: 13 Apr 2025 05:48 PM
Re: Speeds to hub
@Gt77 Where you see Sky Broadband circle with the speed displayed click the arrow pointing to the right and new page will open up.
If you want to test your speed now, then www.fast.com
Speed test like shown is from fast.com
Message posted on 13 Apr 2025 05:40 PM
Re: Speeds to hub
- I can't see anywhere with speed displayed though.
