Discussion topic: Speed
Message posted on 24 Sep 2026 08:32 PM
Speed
I have had full fibre 500 installed today , does it take time to reach max speed
Message posted on 25 Sep 2026 06:18 AM
Re: Speed
@Chrisp12 thecspeed to your hub should be achieved within a couple of hours. However speeds measured on devices connected by WiFi are limited by the speed of the WiFi connection between the hub and the device but yiubshoukd see close to 500Mb/s in the room the hub is in. Inevitably soedds will reduce in rooms further away.
Given few devices can ise spedds over 100Mb/s this is often not an issue in practical use.
Message posted on 25 Sep 2026 09:39 AM
Re: Speed
As @Chrisee indicates, 500Mbs (400Mbs minimum) is speed delivered as far as the Hub over optical fibre and ethernet cable, not WiFi from it.
The 'guaranteed' minimum wireless speed (if the WiFi Max subscription supplement is on the broadband account) is 25Mbs.
