Discussion topic: Speed test
Message posted on 04 Mar 2026 08:32 PM
Speed test
Got fibre 300... Both speed Tests I've used Ookla and Fast... Neither even 90mbps. Am I missing something as Sky say it's 308 on the Sky app!?
Message posted on 04 Mar 2026 08:35 PM
Re: Speed test
Probably, yes. The Sky test reports speed delivered as far as the Hub over optical fibre and ethernet cable: if you are accessing those sites using a wireless device then what you are testing is the local WiFi.
Message posted on 04 Mar 2026 08:37 PM
Re: Speed test
Understood but 75mbps?! Who pays much heed to ethernet speeds as almost everything in the house is WiFi?!
Message posted on 04 Mar 2026 08:47 PM
Re: Speed test
What device are you testing on and in which room, how far from the hub?
Message posted on 04 Mar 2026 08:51 PM
Re: Speed test
My iPhone 17 in back room 2 away from router but there's a booster about 4m away from me open door. The Firestick shows even less speed making streaming nigh impossible on HD so using SD 😞
