Discussion topic: Speed slow on activation day
This message was authored by Kat-W This message was authored by: Kat-W
I've had my Sky connection activated today, and should be getting 60-70mbps on Fibre (to cabinet, not FTTP). I appreciate the line management period, however, the max speed we've got today is 15mbps. Is that normal, or is there a line fault?
Kat-W
Re: Speed slow on activation day
To follow up - the router stats say our downstream is currently (Kbps) 21131, which is far below the minimum 45mbps we're guaranteed.
@Kat-W Could you please post your router stats following the link below.
Kat-W
Hi there, thanks! Adjusted the formatting slightly for ease of reading.
System Up Time: 20:55:43
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 5285827 7294594 0 493944 3772808 20:53:51 LAN Up 368906 179671 0 2776 4336 20:55:43 WLAN (2.4 GHz) Up 1303344 563991 0 16364 55024 20:54:06 WLAN (5 GHz) Up 7506995 5929189 0 0 518376 20:54:05
Broadband Link
Connection Speed
Downstream - 21131 kbps
Upstream - 528 kbps
Line Attenuation
Downstream - D1(24.7 dB), D2(44.3 dB) , D3(66.1 dB)
Upstream -  U0(26.9 dB) , U1(0.0 dB) , U2(0.0 dB)
Noise Margin
Down - 6.3 dB
Up - 6.0 dB
Kat-W
Hi @Highlinder, thanks!
@Kat-W
Sky won't accept a challenge against the Guaranteed Minimum Download Speed during the first ten days after activation.
https://www.sky.com/help/articles/sky-broadband-speed-guarantee
