Discussion topic: Speed issues
This message was authored by: Emlyn
Speed issues
I'm getting around 30 mb/s only instead of 500
Re: Speed issues
@Emlyn if you are measuring speeds on a device connected by WiFi all you are probably measurung is the speed of the WiFi in your home. While 30Mb/s isnt great it is perfectly usable as few apps need much more to work. If you want higher speeds you will need to psy for more WiFi gear but notevthe speed guarantee on Sky's WiFi Max packsge is 25Mb/s in every room in your home.
