Discussion topic: Speed drop from 40 to 20
This message was authored by: lukasz+szachniewi
Hi
My speed drop In one week from 40Mb
To 22Mb.
Problem with hub connection.
Can I cancel my contract with no fee if they did not guarantee speed.?
Any ideas how to solve problem with that issue?
Re: Speed drop from 40 to 20
@lukasz+szachniewi
Could you post your router stats as shown below
Avatar for lukasz+szachniewi
This message was authored by: mae-3
@lukasz+szachniewi
There is a fault on the broadband line that should achieve about 50Mbps downstream but is pegged at 25Mbps because of a fault which will be below your guaranteed minimum downstream speed.
You are on an 80/20Mbps profile and upstream is doing well at 12Mbps.
If Sky/Openreach cannot fix the fault within a month, they should let you out of the contract penalty-free.
Thank you.
And last question If my 18 month contract is end, then Sky can drop my speed if I did not choose renewal?
@lukasz+szachniewi
No, Sky cannot drop the speed because when you have completed an 18-month contract it goes to a rolling contract on by month-by-month basis. And Sky/Openreach are still responsible for fixing a contractual fault.
@lukasz+szachniewi
Also if you could enter your full postal address below and post the table after removing your address it will show us your line profile and whether full fibre is available
