18 Nov 2022 08:59 AM
I can use most apps on my phone via the internet but some won't work. If I turn off my phone's wifi and use my mobile data they work fine!? Even my sky app too is one of them!
18 Nov 2022 04:50 PM
Thanks I had the same idea 'good old turn off the power to reset' and so far so good! 👍😎 thank you for taking the time to help me! Much Appreciated 😊
18 Nov 2022 10:17 AM
Posted by a Superuser, not a Sky employee. Find out more@BluesparkyWhat is the broadband shield set to in my account? Also have you check where you IP is located as some of the pool of IP addesses that Sky have are from Italy.
18 Nov 2022 01:30 PM
Thanks for replying, I have checked my shield it's set at 18 adults level, don't know about the ip address, but as I haven't changed anything and it has worked ok for 2 years plus, I thought it has to be something Sky has done?
18 Nov 2022 01:41 PM
Posted by a Superuser, not a Sky employee. Find out more@BluesparkyIt might be worth a try to leave your broadband off for around 20 minutes to gain a new public IP address to see if that makes a difference and thus enable you to access those sites.
