Discussion topic: Smart TV Buffering
Message posted on 09 Jun 2026 07:45 PM
Smart TV Buffering
Smart TV connected to WiFI GigaHub consistently buffering!
Message posted on 10 Jun 2026 07:39 AM
Re: Smart TV Buffering
@TridentBiker660 wrote:Smart TV connected to WiFI GigaHub consistently buffering!
Is the TV in the same room as the router or an extender? Is it possible to relocate something so that an ethernet cable can be connected?
Have a look at the following to see if they can resolve your problem easily. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
