Discussion topic: My sky tv keeps loosing inter WiFi
This message was authored by: Mikebarraclough
My sky tv keeps loosing WiFi
This message was authored by: Me134
Re: My sky tv keeps loosing inter WiFi
Which Sky TV is it? Sky Q or HD+, Sky Glass, Sky Stream or perhaps a Sky Puck? Is the router/hub in the same room, do you have multi-room?
Have a look at the following to see if they can resolve your problem easily. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
