Discussion topic: Slow upload speeds
This message was authored by: tiggerc1
Slow upload speeds
Sky Broadband Superfast 35  - Download speeds are pretty much as promised however upload speeds which I was checking in order to use PlayStation Remote Play is a low 1.5 - 2.6mps. Phoned Sky Expert line yesterday and a replacement router was suggested with the expert suggesting that I should be getting somewhere between 7-9mps (I'd happily settle for 5). New router duly arrived today but stats are unchanged. Different Expert advised that since upload  speed was in excess of 1.5mps there is nothing that can be done. Agreed with me that my only option to obtain an increase would be to change supplier. Before I start looking for a viable alternative - is this really the best that Sky can do??
Re: Slow upload speeds
@tiggerc1
Could you post your hub stats
Also enter your full address in the wholesale checker and post the table after removing your address from the image
Avatar for tiggerc1
Hi, thanks for such a quick reply. Stats - further info to follow :
Router Statistics
System Up Time: 00:52:34
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 296691 399831 0 897 880 00:50:38 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 12266 86 0 9164 0 00:51:01 WLAN (5 GHz) Up 354362 255172 0 492637 23252 00:42:50
Broadband Link Downstream Upstream Connection Speed 39999 kbps 2027 kbps Line Attenuation D1(16.9 dB) , D2(51.1 dB) , D3(75.3 dB) U0(5.0 dB) , U1(50.3 dB) , U2(0.0 dB) Noise Margin 7.4 dB 6.0 dB
Poll Interval:
Seconds (at least 3s):
@tiggerc1
Its a tad slow but unfortunately isps might take action on upload speeds less than 1Mbps but that usually only entitles you to apply for a voucher
The table from the link i posted would give us more info on other products available
Avatar for tiggerc1
Hi, thanks very much for your help and confirming the earlier advice. Guess I'll test it then decide whether or not to change isp. Thanks again
@tiggerc1
Any other Openreach ISP would be using the same physical circuit, so you'd almost certainly have the same outbound speed limitation.
Avatar for tiggerc1
Thanks again, very disappointing especially when I can see from the text of my contract (taken out more than 18 months ago) that it states the minimum upload speed for my broadband line is 5.5mps with a maximum of  8.4mps and I'm getting nowhere close to either!
Avatar for tiggerc1
Apologies, forgot to attach this - does it suggest that another isp might do better?
Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date High Low High Low       VDSL Range A (Clean)
55 40 8.6 6.4 35 Unavailable Available VDSL Range B (Impacted)
53.6 35 8.5 6 30 Unavailable Available G.fast Range A (Clean)
-- -- -- -- -- Unavailable -- G.fast Range B (Impacted)
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability Date WBC ADSL 2+ Up to 15 -- 8 to 19 Available WBC ADSL2+ Annex M Up to 15 Up to 1.5 8 to 19 Available ADSL Max Up to 7.5 -- 6.5 to 8 Available Fixed Rate 2 -- -- Available
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date WBC SOADSL 2+ Up to 15.0 -- 8.0 to 19.0 Available SOADSL Max Up to 7.5 -- 6.5 to 8.0 Available SOADSL Fixed Rate -- -- -- Available
Other Offerings Availability Date VDSL Multicast Available
Exchange Product Restrictions Status FTTP Priority Exchange N WLR Withdrawal Y SOADSL Restriction N
@tiggerc1 the upload speed in the checker is whst Openreach expected your line to deliver while you know what it achieves in practice. If you switch to another isp using the same line the upload speed will be pretty much identical as its down to the line not the modem.
Switching only makes sense if you have cabelling for another network like Virgin Media in your road or another technology like mobile broadband or Starlink.
Avatar for tiggerc1
Thank you - guess it'll just have to be the long wait for full fibre to come to our village then!
