Discussion topic: Slow speed
Message posted on 06 Jul 2025 11:57 AM
Slow speed
Hi,
I recently had sky max WiFi installed and I'm really disappointed with it so far.
I'm getting a maximum of 60mbps on any device in my house, when I should be getting 800+.
What can be done?
Message posted on 06 Jul 2025 12:06 PM
Re: Slow speed
@FrazerSheppard When did you get the upgrade to the Fibre install, and how are you testing, the service checker will confirm what sky see's on the daily check, just expand the broadband to see what your service is like.
Message posted on 06 Jul 2025 12:32 PM
Re: Slow speed
Hello,
it was installed last Monday and it says the service is fine through sky but if I use speed check on any device, it's not going above 60mbps...
Message posted on 06 Jul 2025 12:41 PM
Re: Slow speed
@FrazerSheppard Does you speed chart look like the linked post but with a lot less data and up in the higher 900 range.!
