Discussion topic: Slow signal
Message posted on 30 Apr 2025 09:52 AM
Slow signal
My iPad is reporting that the network connection is slow in the consetvatory
Message posted on 30 Apr 2025 10:30 AM
Re: Slow signal
@Jan119 pound to a penny the wifi signal is weak in your conservatory which is very common as they are often tge wrong side of a double thickness external wall.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
