Discussion topic: Slow intermittent upstairs
Message posted on 24 Sep 2025 10:20 PM
Message posted on 25 Sep 2025 07:32 AM
Re: Slow intermittent upstairs
@Claire2510 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
