Discussion topic: Slow connection
Message posted on ‎11 Feb 2025 09:28 AM
Slow connection
Download 21.8 mbps upload 88mbps Sky saying 27mbps never had been??
Message posted on ‎11 Feb 2025 12:10 PM
Re: Slow connection
Hi @Hatty60
What package are you on? What speed is showing on the line check in the My Sky app?
Message posted on ‎11 Feb 2025 03:12 PM
Re: Slow connection
Hi, Sky signature Discovery +
Message posted on ‎11 Feb 2025 03:20 PM
Re: Slow connection
Sky say I got 27.8 I've since checked more like 21.8 goes up on checking! 🤨
Message posted on ‎11 Feb 2025 03:35 PM
Re: Slow connection
I meant what broadband package, not Sky TV.
If your line is showing as 27.8mbps then getting 21mbps on a speed test over WiFi is about right, you wouldnt expect much more.
Do you know what your guaranteed minimum figure is?
Message posted on ‎11 Feb 2025 04:02 PM
Re: Slow connection
Sky superfast! 🤣
Message posted on ‎11 Feb 2025 04:25 PM
Re: Slow connection
Okay so its FTTC and could be either up to 40mbps or 80mbps depending on your line. If your current figures are close to your minimum guarantee when you signed up with Sky, then not a lot can be done.
