Discussion topic: Slow broadband
This message was authored by: Richard380
Slow broadband
Broadband very slow 1.3mbps it's hopeless trying to do anything on the internet.
This message was authored by: Me134
Re: Slow broadband
Broadband signal to the router or via wifi?
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not (and it is wifi rather than the broadband signal) you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
