Discussion topic: Slow broadband
Message posted on 01 May 2026 09:02 PM
Slow broadband
Message posted on 02 May 2026 07:37 AM
Re: Slow broadband
@dtypist unless you are running a speed test over a gigabit Ethernet cable connection you are measuring the speed of the WiFi connection in your home which inevitsbly will be slower. WiFi speeds are determined by the layout of your home and what it is built out of. Sky's WiFi Max can supply WiFi extenders to improve coversge but will never give you 900Mb/s in every room but fortunately you only need a fraction of that speed on a device.
Message posted on 02 May 2026 08:28 AM
Re: Slow broadband
Thanks for the response. Fot a 700 sqft single floor apartment, is it normal to get 10Mbps speed for a 900Mbps connection?
I do get a max of 150Mbps when I stand close to the router on some laptops sometimes.
Message posted on 02 May 2026 09:35 AM
Re: Slow broadband
@dtypist wrote:Thanks for the response. Fot a 700 sqft single floor apartment, is it normal to get 10Mbps speed for a 900Mbps connection?
Can you plug one of the laptops into the router to confirm what a wired connection gives?
Not a Sky employee
Sky Q with 2GB UHD box using WiFi
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using WiFi
