Discussion topic: Slow broadband
This message was authored by: Yalda
Message posted on 30 Jul 2025 11:55 AM
Slow broadband
Hello , today your engineer installed my sky hub and it’s working but because the modem is in the bedroom as wiring came from back of the building , the wifi is so weak for the TV in the sitting room, so I need a buster- maximiser
This message was authored by: daveNOS
Find out more
Message posted on 30 Jul 2025 12:00 PM
Re: Slow broadband
@Yalda Sky will only provide a booster if you are a Sky WiFi Max subscriber.
Message posted on 30 Jul 2025 12:18 PM
Re: Slow broadband
@Yalda You just need to move the sky Hub to where it would be better, longer cable is required for YOU to move it if you can!
