Discussion topic: Slow WiFi
This message was authored by: DavidReilly94
Slow WiFi
We are quoted 45mbps (speed tests are showing between 2-4mbps) cannot do anything on WiFi?
Re: Slow WiFi
@DavidReilly94  Router from Sky black or white?
Avatar for DavidReilly94
Level 0 icon
Re: Slow WiFi
White - and thanks for reply
Re: Slow WiFi
@DavidReilly94  What does it tell you when you run the service checker and then running a broadband test to your speed that you are getting to the router and also the history of the speed that you have been getting.
