Discussion topic: Slow WiFi speed
Message posted on 21 Oct 2024 08:28 PM
Slow WiFi speed
Message posted on 22 Oct 2024 08:13 AM
Re: Slow WiFi speed
@Chloeprice30 its not 100% clear if the app is telling you the connection to the hub is running slowly or tge WiFi from the hub to your devices is slow. The former needs to be reported to Sky so they can get your line checked however given the very wet weather many copper lines are affected and Openreach may not accept a fault report. Once the lines dry out things shoud get back to normal.
WiFi speed shouldn't gave changed going by what you have posted but in case a neighbour's network is causing interference try rebooting your hub by switching of the power for a few seconds as that should make it find the best channel to use.
