Discussion topic: Slow WiFi Speeds
Message posted on 24 Oct 2025 12:50 PM
Slow WiFi Speeds
Hi All,
I have recently upgraded to full speed Broadband (1.0G) with a minimum speed of 600Mb. However, my WiFi speeds are consistently at about 90Mb on everything we have. I have checked the speeds with phone and pad right next to the hub but it doesn't show anything better than 90Mb (at best!) with a similar upload speed. I have of course turned the hub off etc. etc. but none of this makes any difference. I am aware that the WiFi speeds will always be less than the broadband speed but surely I should be getting better speeds than I'm currently showing? Or am I simply misunderstanding the situation and all is operating correctly?
Message posted on 24 Oct 2025 01:25 PM
Re: Slow WiFi Speeds
@RobbieF2 With the figure you quote below the 100Mb/s for both the wi-fi and the wireless, then cable from the ONT to the Port4 wan connection is the one to look at, requires all 8 pin connections to be good for a 1Gb/s speed, if not that then say which sky Hub you have.
Also take a look on the service checker, your 30 day history will show you what the profile and the speed test check sky makes daily, 30 day history is there!
Message posted on 24 Oct 2025 04:39 PM
Thanks JimM1,
I have reseated the cable between the ONT and Port 4 but WiFi now flagging 60Mb down and 75Mb up. So nothing changed really. I think that I am probably getting the correct speed in terms of B/B and the Sky checker says there are no issues with either B/B or Wifi but it is still slow... I just don't understand why there should be such a difference between what I should be getting through the WiFi and what I am actually getting through the WiFi. Can I ask does my situation seem right to everyone out there? I have tried to go through Sky but they, through the chat feature, push me to the checker and that isn't flagging a problem. So I'm unsure if I have a problem or not!
BTW the hub is a big black SR203..
Thanks again for the assistance.
Message posted on 24 Oct 2025 04:45 PM - last edited: 24 Oct 2025 04:50 PM
@RobbieF2 See if you can do below link post your stat's up, just allow a couple off minutes to let the fields all fill up! You will see the picture when it is cleared for viewing!
How to read your Sky Hub statistics
A sky service checker history screen shot on a FF500 connection!
