Discussion topic: Slow WiFi Speed - How to request a Sky Max Pod?
This message was authored by: BillS19
I have one room in my house where the WiFi speed is poor and connection sometimes drops and would like to know the process for requesting a Sky Max Pod.
When working from home I'll frequently not have enough bandwidth to support a Teams call or I'll not be able to connect at all.
Happy to buy an extender if anyone can recommend one they've had success with connecting to a Sky Max Hub.
Re: Slow WiFi Speed - How to request a Sky Max Pod?
@BillS19 if you buy Sky's WiFi Max package they  will send the first extender out after a phone call. Adding a third party extender might work but  a lot depends on the distances concerned and how your home is built. If the room is a fair way from the hub there sre better technologies like Powerline networking which use your homes mains wiring to carry the data you can buy these with built-in wifi access points but if being used for business using an Ethernet cable to the adapter is often a better solution.
