Discussion topic: Slow Wi-Fi
Message posted on 19 Jan 2024 06:52 PM
Slow Wi-Fi
It's been two weeks since I've had decent Wi-Fi. It happens sometimes but only lasts a day or two at most, I've never had to do anything about it but this time it's lasting longer. I've done all the checks and whatever they ask, but nothing makes a difference. On checking broadband it does say there is a problem with the Wi-Fi but then it does more checks and says everything is fine. Also puts speed up as 0.1mb/s. I contacted sky via Messenger but they weren't much help. I can't get in contact with them online, your supposed to be able to book an engineer in the checking system but I've not had that opportunity in any of the times I've run the checker. No phone number is given either, not that I want to phone, it gives me too much anxiety just thinking about it, I've not had good experiences in the past when phoning them. Does anyone have any suggestions as to what I could do to sort my Wi-Fi? Thanks in advance.
Message posted on 19 Jan 2024 07:56 PM
Re: Slow Wi-Fi
@FamilyDCould you please post your router stats following the link below.
Message posted on 21 Jan 2024 01:38 PM
Re: Slow Wi-Fi
Message posted on 21 Jan 2024 01:43 PM
Re: Slow Wi-Fi
Could you enter your full postal address below and post the table and notes below after removing your address from the image
Message posted on 21 Jan 2024 02:14 PM
Re: Slow Wi-Fi
Message posted on 21 Jan 2024 02:46 PM
Re: Slow Wi-Fi
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date High Low High Low VDSL Range A (Clean)
80 74 20 19 68.1 Unavailable Available VDSL Range B (Impacted)
80 74 Unavailable Available G.fast Range A (Clean)
330 260.2 50 30.8 234.3 Unavailable Green G.fast Range B (Impacted)
303 230.5 42.1 21.2 210.6 Unavailable Green
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Message posted on 21 Jan 2024 03:06 PM
Re: Slow Wi-Fi
i have tried numerous times to post the table. I am told that there is an unacceptable phrase. 3 pairs of digits. I have changed various parts but them, told still unacceptable due to either further pairs of digits not acceptable or some incorrect HTML. I then tried a message to you but was told again not acceptable.
I have not found a suitable way of changing the info.
Still stuck!
Message posted on 21 Jan 2024 03:11 PM
Re: Slow Wi-Fi
At the top of the table was there any mention of vdsl or further down any mention of wbc fttp.
Your stats do look bad even for sky essentials and furthermore there is no guaranteed minimum download speed.
Message posted on 22 Jan 2024 06:17 PM
Re: Slow Wi-Fi
Apologies. I must have missed that.
The text indicates 80Mbps is available. This is the fastest available fttc superfast speed and you must be very close to the green roadside cabinet and much more stable than what you have at the minute . I would advise you contact sky to upgrade as this would give you a guarantee
Message posted on 22 Jan 2024 06:33 PM
Re: Slow Wi-Fi
Thank you
FamilyD
Message posted on 22 Jan 2024 06:36 PM
Re: Slow Wi-Fi
And to be honest sky would be reluctant to repair that length of copper cable back to the exchange when they already would have fibre some 300 metres away at the cabinet .
Message posted on 22 Jan 2024 06:37 PM
Re: Slow Wi-Fi
Contact sky asap as available slots are in high demand
Message posted on 22 Jan 2024 06:42 PM
Re: Slow Wi-Fi
Ok.
FamilyD
