Discussion topic: Slow Wi Fi Vs contract
This message was authored by: Manorozco
I recently  joined SKY with a contract for 500Mbps, I already connected Sky Hub and the Wi Fi signal works but when I run the speed test it shows a very weak signal.
Attached test result and hub status
Re: Slow Wi Fi Vs contract
@Manorozco
The 500Mbs for Ultrafast 2 (400Mbs Guaranteed Minimum Download Speed) applies to the speed delivered over optical fibre to the router, not WiFi broadcast from it.
@Manorozco
You may get some improvement by moving the Hub away from that cabinet: a large chunk of metal with (presumably) electronic devices inside isn't ideal for WiFi.
Avatar for Manorozco
thanks @TimmyBGood
not good news for me
Apparently most of the rooms are wired with ethernet outlet coming from a switch,
so any advice to increase wi fi signal? maybe a booster in one of the rooms?
