Discussion topic: Sky
This message was authored by: A1W
Sky
Broadband is poor and Sky isn't working
Re: Sky
@A1W
Poor or not working?
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
