Discussion topic: Option61/MER needed for sky on virgin fibre?
This message was authored by: maulwurf
Moving to brand new fibre from cable. Cable was Virgin installed and so is the new fibre.
I have changed from virgin to sky ultrafast plus and they/their contractors are installing
the outside cable and indoor ONT etc. here next week.
(Dublin, Ireland)
I have seen that any router I buy (to replace the sky hub) must support Option61/MER.
Is this the case even when the underlying fibre network is a virgin fibre network?
I am not an expert, so a simple explanation would be most welcome 🙂
Re: Option61/MER needed for sky on virgin fibre?
@maulwurf Pretty sure the ROI is a completely different connection method to the UK!
Think this is the ROI settings needed below.
Connection type          pppoe
Username                        anything@skydsl
Password                        anything
Vlan                                   enable and type in 10
