Discussion topic: Sky wifi
This message was authored by: DEEZOE
Sky wifi
Sky hub box not working
Re: Sky wifi
@DEEZOE
Not a lot to go on but if you haven’t done it already use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
