Discussion topic: Sky wifi max router
Message posted on 22 Apr 2025 02:52 PM
Sky wifi max router
Message posted on 22 Apr 2025 03:26 PM
Re: Sky wifi max router
@D3s The WiFi Max router may not help directly with your situation - the WiFi range of WiFi Max is no greater than that of prior Sky routers. What it does do is allow more devices to transmit/receive at the same time, helping out where earlier routers were overwhelmed/congested by the number of devices all trying to talk to the router at the same time.
If your issue is that you have lots of devices (streaming boxes/TVs, phones, tablets etc) all in use at the same time and your router is struggling then WiFI Max will help. If the issue on the other hand is one of signal strength/range of the router for devices you need to use on WiFi, then WiFi range boosters are probably the way to go.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
