Discussion topic: No wifi
Message posted on 22 Apr 2025 03:40 PM
No wifi
Message posted on 22 Apr 2025 03:41 PM
Re: No wifi
@bigvern1960
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
