Discussion topic: Sky wifi cuts out when PC plugged in
Message posted on 04 May 2024 07:04 PM
Hey,
I have a very weird issue with the broadband, whenever the PC is turned on that is plugged directly into the sky hub the wifi starts acting up (slower speeds, cutting out, wifi crashes etc) but this only happens when the PC is plugged into the hub via Ethernet, if the PC is connected through WiFi the internet is completely fine and doesn't have any issues, anybody know why?
thanks
Message posted on 07 May 2024 11:21 AM
Re: Sky wifi cuts out when PC plugged in
What PC is it? Or more specifically what ethernet adapter/card is built into it? Are you using a Cat5e or above cable? Is the PC set to automatically assign an IP or manual?
Message posted on 08 May 2024 02:47 AM
It's using the 2.5G Ethernet port built into the motherboard. The cable is indeed cat5e and it's set to automatically assign an IP
Message posted on 09 May 2024 10:07 AM
Have you tried manually setting the ports speed in the PC settings? E.g. Try setting it to 100mbps or 1000mbps, see if that makes any difference
Message posted on 14 May 2024 01:30 PM
Hey was trying to figure out how to do this because there is no option on the pc to limit the speed, however I do suspect that's the reason the wifi crashes, I just plugged back in the Ethernet and it was fine and then as soon as I tried to download something on the pc with Ethernet it just crashed the whole router, maybe getting a different router from a third party might be better?
